[GRASS5] Re: Specifying 'database' in various modules
    Radim Blazek
    blazek at itc.it
    Mon Jan 24 04:54:43 EST 2005
Radim Blazek wrote:
> Michael Barton wrote:
>> Radim and Markus,
>> This is a request for a bit of fine tuning on the database modules. But I
>> also want to see what everyone thinks about it as it wouldn't do to make
>> things more difficult.
>> V.in.db and other database modules have a common format for specifying
>> attribute tables--which is a very helpful thing. There are two fields to
>> identify which table to use for attributes: one is called "database"
>> and the
>> other is called "table". In some cases, the "database" field is a
>> host/database specification string (as in mysql). In other cases it is
>> simply a path to a table location (as in ASCII or dbf tables). I'd
>> like to
>> suggest that the descriptive text that appears in the autogenerated
>> GUI be
>> called "specify database or path to data table". This will make it easier
>> for new users (and forgetful old users like me) to know what to put in
>> this
>> field.
>> A browse button would be nice here too, though only useful for those
>> cases
>> where database is a path.
>> Thanks
>> Michael
> OK, note that you can use 'label' (name/short description) and
> 'description' (long description), so something like
> database_opt ->label       = "Database";
> database_opt ->description = "For dbf driver the path to the directory..."
> Radim
Better to add a new standard options to gislib, because both driver and
database are reused in many modules. Look at G_define_standard_option()
in lib/gis/parser.c, there is already G_OPT_WHERE.
You have to define also new STD_OPT in include/gis.h, (G_OPT_DRIVER,
G_OPT_DATABASE)
Then in modules use just:
driver_opt = G_define_standard_option(G_OPT_DRIVER);
database_opt = G_define_standard_option(G_OPT_DATABASE);
Radim
