[GRASS5] Re: using r.in.gdal on png provides negative
south/west
Russell Nelson
nelson at crynwr.com
Mon Jan 24 20:42:55 EST 2005
Glynn Clements writes:
> Hamish wrote:
> > > That's one of the shoals driving unexperienced users into deepest
> > > depression - displaying the imported stuff does show a blank screen
> > > which may mislead to the opinion that the import failed: wrong image
> > > format, gdal not working, dunno whatever!
> > Regardless of this "feature", all tutorials should really be mentioning
> > the use of 'g.region raster=newmap' before displaying a new map ...
> It's more likely that they should be mentioning the use of r.region to
> set the map's boundaries.
Even better: r.in.gal should set the region unless you specify the
-nr option.
--My blog is at angry-economist.russnelson.com | Freedom means allowing
Crynwr sells support for free software | PGPok | people to do things the
521 Pleasant Valley Rd. | +1 315-323-1241 cell | majority thinks are
Potsdam, NY 13676-3213 | +1 212-202-2318 VOIP | stupid, e.g. take drugs.
