[GRASS5] g.region region= bug
Markus Neteler
neteler at itc.it
Thu Jan 27 16:33:45 EST 2005
I found an (at least undesired) error which prevents
me from setting the region to settings stored in other than
current mapset (Spearfish example):
GRASS 6.0.cvs:~ > g.region region=county
ERROR: can't read region <county> in <PERMANENT>
GRASS 6.0.cvs:~ > g.gisenv |grep -i mapset
MAPSET='user1';
-> we are in user1, not in PERMANENT
GRASS 6.0.cvs:~ > g.list region
region definition files available in mapset user1:
zoom_temp
region definition files available in mapset PERMANENT:
9961 county subregion.NW
Related code of general/g.region/cmd/main.c :
/* region= */
if (name = parm.region->answer)
mapset = G_find_file ("windows", name, "");
if (!mapset)
G_fatal_error ("region <%s> not found", name);
if (G__get_window (&window, "windows", name, mapset) != NULL)
G_fatal_error ("can't read region <%s> in <%s>", name, mapset);
I am not sure why it doesn't work as expected.
Markus
