[GRASS5] db.execute
Stephan Holl
sholl at gmx.net
Fri Jan 28 03:07:52 EST 2005
Hello grass at forreststevens.com,
On Thu, 27 Jan 2005 09:22:49 -0700 <grass at forreststevens.com> wrote:
> Because the id field is an integer it doesn't require single quotes:
> echo "INSERT INTO laender ( id, cat ) VALUES(86, 'YY')"|db.execute
Thank you... I was blind when setting up the insert-statement. Now it
works like a charme..
Cheers
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050128/2e2cd4ad/attachment.bin
