[GRASS5] setting the initial region
Hamish
hamish_nospam at yahoo.com
Mon Jan 31 23:41:55 EST 2005
> >> there was talk a little while back about resetting the default region.
> >> (currently you have to edit DEFAULT_WIND manually)
> > what about
> > g.region -d --o
> > or
> > g.region save=default --o
> Sorry for interrupting, but what is that --o switch? I can't find it in
> g.region manual.
It tells GRASS that it is ok to overwrite existing maps.
It wasn't in any of the manuals because it is brand new.
you can set this to be assummed by setting the GRASS variable OVERWRITE:
g.gisenv set="OVERWRITE=1"
Hamish
