[GRASS5] GRASS 6.0.1 release schedule
Hamish
hamish_nospam at yahoo.com
Sat Jul 2 01:15:45 EDT 2005
> I think that it's time to get out GRASS 6.0.1 bugfix release.
> The 6.0.1 version should be in a good shape now.
> Here a proposed schedule:
Sounds good.
To recall a bug list from a previous email:
Subject: [GRASS5] Re: [Pkg-grass-general] update
Date: 2005-05-28 01:01:57 GMT
I wrote:
> [Pkg-grass-general]
> > > GRASS 6.0.1 has not been released yet.
> > So we should do that!
> critical bugs to fix:
> cs2cs doesn't see GRASS's NTv2 grid files. see:
> http://bugzilla.remotesensing.org/show_bug.cgi?id=834
Fixed by Paul. I have lightly tested; don't know if it has been applied
to the 6.0.x release branch.
> v.in.garmin - add more checks to survive above bug when downloading
> track.
done. Merged.
> r.out.gdal - broken with quoting problem.
done. I don't know if it has been applied to the 6.0.x release branch.
> r.terraflow still using insecure temp files
Laura pointed out that r.terraflow uses mkstemp() to create the temp
files in raster/r.terraflow/IOStream/lib/src/ami_stream.cc. So the temp
files should be secure after all.
> 100% cpu usage during mouse ops. Real problem for multi-user machines
> and when using GRASS over a network connection.
outstanding, not good, but not release critical.
others?
Hamish
