[GRASS5] Re: [GRASSLIST:7447] NVIZ compile error
Glynn Clements
glynn at gclements.plus.com
Tue Jul 5 11:33:05 EDT 2005
[CC to developers]
Trevor Wiens wrote:
> I've finally decided to move to 6.0 from the 6.0 beta2. When compiling
> I get a complaint about nviz with the suggestion to go the nviz
> directory and execute make. Upon doing that I get the following error.
> /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2eea): In function `glXGetMscRateOML':
> : undefined reference to `XF86VidModeQueryVersion'
> /usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2f1a): In function `glXGetMscRateOML':
> : undefined reference to `XF86VidModeGetModeLine'
Try to figure out why you don't have a shared libGL.
Recent Xorg versions of libGL depend upon libXxf86vm. If you had a
shared libGL (libGL.so), it would have dependency information which
would cause libXxf86vm to be linked automatically, e.g.:
$ ldd /usr/lib/libGL.so
libpthread.so.0 => /lib/libpthread.so.0 (0x40079000)
libXxf86vm.so.1 => /usr/lib/libXxf86vm.so.1 (0x400cc000)
libXext.so.6 => /usr/lib/libXext.so.6 (0x400d2000)
libX11.so.6 => /usr/lib/libX11.so.6 (0x400e0000)
libdl.so.2 => /lib/libdl.so.2 (0x401a9000)
libc.so.6 => /lib/libc.so.6 (0x401ad000)
/lib/ld-linux.so.2 (0x80000000)
Static libraries don't include dependency information.
Note to developers: the libGL check in configure.in should probably be
updated to try using -lXxf86vm if the initial attempt fails.
