[GRASS5] Re: Vector points and topology
Markus Neteler
neteler at itc.it
Wed Jul 6 09:21:32 EDT 2005
On Mon, Jul 04, 2005 at 10:31:21AM +0200, Radim Blazek wrote:
> On 7/1/05, Markus Neteler <neteler at itc.it> wrote:
> > - how to speed up v.out.ogr export (230 minutes for 100k points)
> It has nothing to do with topology. The problem is random access to attributes.
> It is necessary to change v.out.ogr so that it opens select cursor
> for attributes sorted by cat and then it must process geometry
> in the cats order (using category index) and read attributes sequentialy
> from the opened select cursor (checking always if the cat is available).
Ok. Is there any example in GRASS to study which changes are needed?
> > - which is the module I should use as reference to explain vector
> > programming *with* attributes?
> It depends on specific task, v.to.rast, v.extract or v.out.ogr are
> using different
> approach. It is always necessary to take a module doing something similar
> to the task you want to do.
OK.
Markus
