[GRASS5] Re: grass5 digest, Vol 1 #1749 - 10 msgs
Michael Barton
michael.barton at asu.edu
Wed Jul 6 11:34:12 EDT 2005
Toby
I just went through this teaching a class on GIS and GRASS, using a room
full of XP boxes. Eventually, the folks at the University of Valencia made a
nice CD that allowed you to double click a compressed file and install,
GRASS, Cygwin, and my version of the demo data set. But that is another
story.
Here is my advice.
First, use the 6.1-cvs version rather than 6.0. There are problems with 6.0
for Cygwin. Even if you get it to run, it is likely to lock up unexpectedly.
These seem to be fixed in the 6.1-cvs-4 version now available. Make sure you
download the grass61.bat file. You'll find it a bit hidden further down on
the web page. 6.1 won't run with grass60.bat.
Second, the error you describe is most likely due to permission problems.
When my students had this error, inevitably it turned out that they did not
have administrative access to their computer. XP was set up by someone else
in the family or a store that neglected to make them administrators. I don't
know if this is your problem, but it seems a good place to start.
Third, I'll expand on Hamish's advice a bit. Start Cygwin (i.e., start with
the cygwin batch file). From the Cygwin prompt, type
startxwin.bat
OR
startxwin.sh
[You have to press return after each command]
Try the *.bat first as it seems to be most consistently OK.
You'll get an xwindows terminal. At the terminal prompt, type
grass61
This should give you reasonably clear error messages about what is not
working.
Hope this helps.
Michael
On 7/6/05 3:01 AM, "grass5-request at grass.itc.it"
<grass5-request at grass.itc.it> wrote:
> Send grass5 mailing list submissions to
> grass5 at grass.itc.it
> To subscribe or unsubscribe via the World Wide Web, visit
> http://grass.itc.it/mailman/listinfo/grass5
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass5-admin at grass.itc.it
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass5 digest..."
> Today's Topics:
> 1. Re: GRASS 6.0.1 release question (Markus Neteler)
> 2. Re: GRASS 6.0.1 release question (Markus Neteler)
> 3. Re: r.random broken (Michael Barton)
> 4. Re: [GRASSLIST:7386] ANOUNCEMENT: GRASS 6 Exension Manager (Michael
> Barton)
> 5. Re: [GRASSLIST:7447] NVIZ compile error (Glynn Clements)
> 6. Re: Commit sql parser patch, please (Glynn Clements)
> 7. [bug #3396] (grass) db.describe drop-down list (Request Tracker)
> 8. [bug #3397] (grass) installation problem for Windows XP (Request
> Tracker)
> 9. Re: [bug #3397] (grass) installation problem for Windows
> XP (Hamish)
> grass5 mailing list
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
