[GRASS5] Re: r.flow: strange compile error M_PI
Wed Jul 13 20:46:35 EDT 2005
Markus Neteler wrote:
> I have tried to clean up the [M_]PI mess a bit,
> hope I got it right. It is now defined in include/gis.h.
> Untouched (not sure how to solved this - precision):
> ./lib/vector/rtree/gammavol.c
> ./lib/vector/rtree/rect.c
> ./lib/vector/rtree/sphvol.c
> ./lib/cdhc/as241.c
> ./lib/cdhc/cdh.f
> ./lib/cdhc/dagstndn.c
> Unclear:
> ./vector/v.label/main.c
> which came with 3.1415926535897932384626433832795029L definition (changed to M_PI now).
Change all of them (except cdh.f) to use the definition from gis.h.
I'm quite certain that none of the ones which are using a
lower-precision definition really need it to have that exact value.
And v.label definitely doesn't need a "long double" definition.
