[GRASS5] dbCatVal
Glynn Clements
glynn at gclements.plus.com
Sun Jul 17 07:34:03 EDT 2005
Radim Blazek wrote:
> Is it harmless (for binary compatibility) to change
> typedef struct {
> int cat; /* category */
> int isNull;
> union {
> int i;
> double d;
> } val;
> } dbCatVal;
> to
> typedef struct {
> int isNull;
> union {
> int i;
> double d;
> dbString *s;
> dbDateTime *t;
> } val;
> } dbCatVal;
> Pointers should not take > 8 bytes (double) I believe.
Pointer and double could have different alignment requirements.
10-byte pointers on x86/64 are a theoretical possibility, but I don't
think that any platform actually uses them.
