[bug #3436] (grass) Re: [GRASS5] Patch for bug#3345 (debian bug#313307)
Request Tracker grass-bugs at intevation.de
Mon Jul 18 04:28:34 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3436
Daniel,
thanks for the new patch, seems to work fine (I tested a few
man pages).
Applied to both 6.1-CVS and 6.0-CVS.
Markus
On Sat, Jul 16, 2005 at 08:42:47PM -0500, Daniel Calvelo Aros wrote:
> Ok, there you are. This patch does correctly escape backslashes before
> processing and then re-escapes single and double quotes where they could be
> active characters for roff.
> I noticed that backslashes are seldom used in the docs, but on two occasions
> they are intended to be actual roff escapes:
> - r.mapcalc uses '\e' to denote continuation once. It uses '\' one paragraph
> later for the same. I think with this patch applied the '\e' should be changed
> to '\'. Note that for roff \e is the escape character, which can be changed,
> whereas \(rs is the backslash glyph. BTW, the docs for r.mapcalc contain
> several tables written as preformatted text, which can be rewritten as proper
> tables.
> - r.watershed uses both \u and \d escapes, which are roff codes for switching
> on and off superscript. Those should be changed to something html-ish.
> Otherwise, occurrences of '\' are for verbatim continuation lines or as
> html-unescaped shell-like special characters: \t, \n,...
> Hope I got it right this time. Sorry for the previous noise.
> -- Daniel Calvelo Aros
--- Headers Follow ---
>From neteler at itc.it  Mon Jul 18 10:28:34 2005
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 957331006BC
	for <grass-bugs at lists.intevation.de>; Mon, 18 Jul 2005 10:28:34 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id EBD0C36EDF
	for <grass-bugs at lists.intevation.de>; Mon, 18 Jul 2005 10:28:31 +0200 (CEST)
Received: from mail.itc.it (ns.itc.it [217.77.80.3])
	by mail.intevation.de (Postfix) with ESMTP id 6FDFA36E43
	for <grass-bugs at intevation.de>; Mon, 18 Jul 2005 10:28:29 +0200 (CEST)
Received: from ntmain.itc.it ([10.0.20.40])
	by mail.itc.it (8.12.11/8.12.11) with SMTP id j6I8SR3Q020686;
	Mon, 18 Jul 2005 10:28:27 +0200
Received: from orchestra.itc.it ([10.0.10.11])
 by ntmain.itc.it (SMSSMTP 4.1.5.31) with SMTP id M2005071810282731516
 ; Mon, 18 Jul 2005 10:28:27 +0200
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j6I8SQvR010714;
Received: from thuille.itc.it. (localhost.localdomain [127.0.0.1])
	by thuille.itc.it. (8.13.1/8.13.1) with ESMTP id j6I8SQXd011342;
	Mon, 18 Jul 2005 10:28:26 +0200
Received: (from neteler at localhost)
	by thuille.itc.it. (8.13.1/8.13.1/Submit) id j6I8SQTI011341;
Date: Mon, 18 Jul 2005 10:28:26 +0200
To: daniel.calvelo at minag.gob.pe, grass-bugs at intevation.de
Cc: Steve Halasz <debian at adkgis.org>, grass5 at grass.itc.it
Subject: Re: [GRASS5] Patch for bug#3345 (debian bug#313307)
Message-ID: <20050718082825.GA10709 at thuille.itc.it>
Mail-Followup-To: daniel.calvelo at minag.gob.pe,
	grass-bugs at intevation.de, Steve Halasz <debian at adkgis.org>,
References: <20050713021606.M26168 at minag.gob.pe> <1121222254.4137.16.camel at marcy> <20050713102111.GA23537 at thuille.itc.it> <20050713185442.M81779 at minag.gob.pe> <20050714083207.GE20871 at thuille.itc.it> <20050717013404.M86465 at minag.gob.pe>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
In-Reply-To: <20050717013404.M86465 at minag.gob.pe>
User-Agent: Mutt/1.4.1i
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
