[GRASS5] [bug #3432] (grass) Stats tracking
Markus Neteler neteler at itc.it
Mon Jul 18 09:23:44 EDT 2005
On Sun, Jul 17, 2005 at 09:14:10PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3432
> Subject: Stats tracking
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.0
> Dave Sampson
> Stats tracking of GRASS operations dunped to text log file.
> eg what operation was used for how long. how many iterations?
> present option for user to provide this data back to central server. process the data to see what areas of GRASS and what moduals are most often used.
> This can help decide where development focuses should continue, or if something is under developed based on its use or lack of use.
This could be done by adding some code to lib/gis/parser.c
which simply writes all GRASS commands into a text file (probably
with time stamp). The file should be stored in the mapset
directory.
I would be interested to see some stats on my own commands...
Markus
