[GRASS5] GRASS release policy needed
Markus Neteler
neteler at itc.it
Thu Jul 21 08:05:27 EDT 2005
Hi developers and power users,
in June I made a try to release GRASS 6.0.1:
http://grass.itc.it/pipermail/grass5/2005-June/018798.html
It turned out to be more complicated:
http://grass.itc.it/pipermail/grass5/2005-July/thread.html#18820
Some observations
1. the bugtracker is full of (old) bugs
2. some of the bugs are known for years, but nobody is interested/able
to fix them
3. some of the well know bugs have hold the intended release, but see 2.
4. While the release procedure is well documented in doc/howto_release.txt
it is rather unclear when and under which conditions to release.
Opinion
We should implement a better release management.
I think that a long standing bug (see 2. above) should not hold a release
if noone offers to fix it in *reasonable* time (e.g., range of days).
Currently a couple of important fixes are still officially unpublished
such as (nearly randomly selected):
2005-05-10 11:58 radim
* db/drivers/dbf/dbfexe.c: set columns to null before insert
2005-05-10 10:23 hamish
* include/gisdefs.h: G_is_little_endian() was missing [merge from
HEAD]
2005-04-29 11:37 radim
* lib/db/: dbmi_client/start.c, dbmi_driver/driver.c: set correctly
GISRC mode
2005-04-29 10:12 radim
* db/drivers/dbf/dbfexe.c: free statement <- the famous LIDAR fix
2005-04-20 18:04 radim
* lib/vector/Vlib/map.c: use original key also for index
2005-04-20 17:56 radim
2005-03-31 18:48 radim
* lib/vector/Vlib/intersect.c: segment and line intersection fix
2005-03-30 15:24 markus
* lib/proj/... fix ETRS89 datum problems
2005-03-30 10:03 markus
* raster/r.proj/: bilinear.c, bordwalk.c, cubic.c, main.c,
nearest.c: Morten Hulden...
2005-03-18 11:49 markus
* lib/gis/make_loc.c: meter -> meters
2005-03-16 17:47 radim
* lib/vector/Vlib/bridges.c: endless loop fix on zero length
boundaries
2005-03-14 09:05 radim
* vector/v.db.connect/main.c: field info fix
Currently we have 132 unreleased fixes in 6.0-CVS. IMHO a pity to not
make them available officially to the user community.
Just my 0.02 Eurocent
Markus
