[GRASS5] i.smap problems
Markus Neteler neteler at itc.it
Fri Jul 29 05:17:34 EDT 2005
Brad,
since I have access to a 64bit box now, could you please
post how you generated the 'b' group/subgroup?
Also the g.region settings?
Markus
On Fri, Jul 22, 2005 at 02:21:08PM -0700, Brad Douglas wrote:
> I've had this issue for some time and am now just looking into it.  I
> don't know if this is a 64-bit issue or not.  Can anyone replicate this
> under 32-bit architectures?
> I'm no expert with gdb, either and use it so rarely I cannot remember
> how to probe structures:
> GRASS 6.1.cvs (spearfish60):/usr/src/grass6 > gdb --args i.smap gr=b
> sub=b sig=b out=b
> [snip]
> (gdb) run
> Starting program: /opt/gis/grass-6.1.cvs/bin/i.smap gr=b sub=b sig=b
> out=b
> Processing rows 1-128 (of 700), cols=1-128 (of 950)
> Processing rows 1-128 (of 700), cols=129-256 (of 950)
> Processing rows 1-128 (of 700), cols=257-384 (of 950)
> Processing rows 1-128 (of 700), cols=385-512 (of 950)
> Processing rows 1-128 (of 700), cols=513-640 (of 950)
> Processing rows 1-128 (of 700), cols=641-768 (of 950)
> Processing rows 1-128 (of 700), cols=769-896 (of 950)
> Processing rows 1-128 (of 700), cols=897-950 (of 950)
> Processing rows 129-256 (of 700), cols=1-128 (of 950)
> Processing rows 129-256 (of 700), cols=129-256 (of 950)
> Processing rows 129-256 (of 700), cols=257-384 (of 950)
> Processing rows 129-256 (of 700), cols=385-512 (of 950)
> Processing rows 129-256 (of 700), cols=513-640 (of 950)
> Processing rows 129-256 (of 700), cols=641-768 (of 950)
> Processing rows 129-256 (of 700), cols=769-896 (of 950)
> Processing rows 129-256 (of 700), cols=897-950 (of 950)
> Processing rows 257-384 (of 700), cols=1-128 (of 950)
> Processing rows 257-384 (of 700), cols=129-256 (of 950)
> Processing rows 257-384 (of 700), cols=257-384 (of 950)
> Processing rows 257-384 (of 700), cols=385-512 (of 950)
> Processing rows 257-384 (of 700), cols=513-640 (of 950)
> Processing rows 257-384 (of 700), cols=641-768 (of 950)
> Processing rows 257-384 (of 700), cols=769-896 (of 950)
> Processing rows 257-384 (of 700), cols=897-950 (of 950)
> Processing rows 385-512 (of 700), cols=1-128 (of 950)
> Processing rows 385-512 (of 700), cols=129-256 (of 950)
> Processing rows 385-512 (of 700), cols=257-384 (of 950)
> Processing rows 385-512 (of 700), cols=385-512 (of 950)
> Processing rows 385-512 (of 700), cols=513-640 (of 950)
> Processing rows 385-512 (of 700), cols=641-768 (of 950)
> Processing rows 385-512 (of 700), cols=769-896 (of 950)
> Processing rows 385-512 (of 700), cols=897-950 (of 950)
> Processing rows 513-640 (of 700), cols=1-128 (of 950)
> Processing rows 513-640 (of 700), cols=129-256 (of 950)
> Processing rows 513-640 (of 700), cols=257-384 (of 950)
> Processing rows 513-640 (of 700), cols=385-512 (of 950)
> Processing rows 513-640 (of 700), cols=513-640 (of 950)
> Processing rows 513-640 (of 700), cols=641-768 (of 950)
> Processing rows 513-640 (of 700), cols=769-896 (of 950)
> Processing rows 513-640 (of 700), cols=897-950 (of 950)
> Processing rows 641-700 (of 700), cols=1-128 (of 950)
> Processing rows 641-700 (of 700), cols=129-256 (of 950)
> Processing rows 641-700 (of 700), cols=257-384 (of 950)
> Processing rows 641-700 (of 700), cols=385-512 (of 950)
> Processing rows 641-700 (of 700), cols=513-640 (of 950)
> Processing rows 641-700 (of 700), cols=641-768 (of 950)
> Processing rows 641-700 (of 700), cols=769-896 (of 950)
> Processing rows 641-700 (of 700), cols=897-950 (of 950)
> Writing [b] ...
>    0%
> Program received signal SIGSEGV, Segmentation fault.
> 0x0000000000402887 in write_img (img=Variable "img" is not available.
> ) at write_img.c:28
> 28  files->cellbuf[col] = (CELL)S->ClassSig[class].classnum;
> (gdb) bt
> #0  0x0000000000402887 in write_img (img=Variable "img" is not
> available.
> ) at write_img.c:28
> #1  0x0000000000402eb3 in segment ()
> #2  0x000000000040224a in main (argc=5, argv=Variable "argv" is not
> available.
> ) at main.c:27
> (gdb)
> Brad Douglas <rez at touchofmadness.com>
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
