[GRASS5] Re: Vector points and topology
Markus Neteler
neteler at itc.it
Fri Jul 29 12:34:10 EDT 2005
I was looking again (a bit) at the potential memory leak
of the vector library.
Hamish's analysis
http://bambi.otago.ac.nz/hamish/grass/memleak/v.in.ascii/
indicates
The main offenders are:
RTreeNewNode (node.c:47)
dig_alloc_node (struct_alloc.c:46)
dig_alloc_lines (struct_alloc.c:130)
Looking at the code:
lib/vector/rtree > grep RTreeNewNode *.c
index.c: x = RTreeNewNode();
index.c: newroot = RTreeNewNode(); /* grow a new root, & tree taller */
node.c:struct Node * RTreeNewNode(void)
split_l.c: *nn = RTreeNewNode();
split_q.c: *nn = RTreeNewNode();
I see that RTreeNewNode() - which uses malloc() is used a couple of times
but probably free() isn't used where needed:
lib/vector/rtree > grep free *.c | grep -iv 'free software'
index.c: free(p);
node.c: free(p);
node.c:/* Destroy (free) node recursively. */
Maybe someone knowing more that me could inspect if a free() is
missing here? RTreeNewNode(), according to valgrind, seems to
cause some troubles.
Markus
