[GRASS5] i.smap problems
Brad Douglas rez at touchofmadness.com
Sat Jul 30 03:41:50 EDT 2005
On Sat, 2005-07-30 at 00:33 -0700, Brad Douglas wrote:
> On Fri, 2005-07-29 at 11:17 +0200, Markus Neteler wrote:
> > since I have access to a 64bit box now, could you please
> > post how you generated the 'b' group/subgroup?
> > Also the g.region settings?
> After trying the same problem on a 32bit box, I realized that I had
> incorrectly generated the signature file.  Once generated properly, all
> was well.
> I'm going to add some further (simple) checks to i.smap to validate the
> integrity of the signature file.
UPDATE:
I_ReadSigSet() is broken and returns true regardless of signature
validity.  Fix will be applied soon.
Brad Douglas <rez at touchofmadness.com>
