[GRASS5] [bug #3317] (grass) Some GRASS 6.0.0 bugs
Request Tracker
grass-bugs at intevation.de
Sun Jun 5 16:50:21 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3317
Some GRASS 6.0.0 bugs that would take too much modem time to mail separately:
d.zoom: vector layer shows beyond raster layer to fill up empty part
of monitor.
man page says v.univar is for rasters:
DESCRIPTION
v.univar calculates univariate statistics of a raster map
$ v.info ...
Type of Map: Vector (level: 2)
It should say "levels: 2", No?
v.what.rast sends six bells (^G) to the screen each run.
This returns an error but doesn't say why.
$ d.vect display=attr,shape attrcol=address map=bends2 xref=center \
lcolor=black lsize=7 bgcolor=white; echo $?
1
It only draws the shapes.
Oh, I needed llayer=2. Well it should still say something instead of
just exiting 1.
This allows me to say attrcol without causing an error:
$ d.vect display=cat attrcol=address map=bends2 xref=center \
$ man d.vect mentions 5.7 tutorial, not 6.0... better just say 'tutorial'
d.vect has no way to adjust line thickness
--- Headers Follow ---
>From jidanni at jidanni.org Sun Jun 5 22:50:21 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 7FE6B1006CC
for <grass-bugs at lists.intevation.de>; Sun, 5 Jun 2005 22:50:21 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 02BD936EA4
for <grass-bugs at lists.intevation.de>; Sun, 5 Jun 2005 22:50:20 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 2EAC936CE4
for <grass-bugs at intevation.de>; Sun, 5 Jun 2005 22:50:19 +0200 (CEST)
Received: from [218.187.77.182] (port=32969 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:AES256-SHA:256) (Exim 4.51 #0)
id 1Df24U-000OoB-1P by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Mon, 06 Jun 2005 02:20:15 +0530
To: grass-bugs at intevation.de
Subject: Some GRASS 6.0.0 bugs
Date: Mon, 06 Jun 2005 04:01:10 +0800
Message-ID: <87ll5oefp5.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
