[GRASS5] [bug #3335] (grass) v.surf.rst, i.rectify, ps.map
Request Tracker
grass-bugs at intevation.de
Wed Jun 8 19:52:12 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3335
$ v.info bla
Type of Map: Vector (level: 2)
This must mean (Version: 2)! As my scientific tests prove that it is
not layers.
$ v.surf.rst ...
will require 11440496 bytes of disk space for temp files
Not to mention about as much for permanent files, which perhaps you
might also mention.
$ i.rectify -c input=rawortho group=s2 order=1 extension=1
Input file rawortho does not exist in group s2.
Try:
s1
rawortho
ERROR: Exit!
But that's what I tried.
So give a better message when there are not enough items on a line in
$ cat grassdata/shangcheng/addressing/group/s2/REF
s1 addressing rgb
rawortho addressing
Also the mail i.rectify sends when all is well has the Subject stuck
into the body.
$ man ps.map
No way to give a simple scalebar a white background.
Mention to give some high number for scalebar's number parameter, if
one only wants numbers at the front and end of the scalebar.
One can place text on the map with coordinates or percentages, but a
scalebar must be positioned with inches.
No mention of how to get a north arrow onto the map.
--- Headers Follow ---
>From jidanni at jidanni.org Thu Jun 9 01:52:12 2005
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 9B8EC101F00
for <grass-bugs at lists.intevation.de>; Thu, 9 Jun 2005 01:52:12 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id E532E36EA4
for <grass-bugs at lists.intevation.de>; Thu, 9 Jun 2005 01:52:09 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 8942436CE4
for <grass-bugs at intevation.de>; Thu, 9 Jun 2005 01:52:07 +0200 (CEST)
Received: from [218.187.83.194] (port=32846 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:AES256-SHA:256) (Exim 4.51 #0)
id 1DgAL4-0009Z1-DF by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Thu, 09 Jun 2005 05:22:03 +0530
To: grass-bugs at intevation.de
Subject: v.surf.rst, i.rectify, ps.map
Date: Thu, 09 Jun 2005 07:11:41 +0800
Message-ID: <87zmu01m1e.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
