[GRASS5] PATCH: sql expression parser
Daniel Calvelo Aros
dcalvelo at minag.gob.pe
Fri Jun 10 05:13:42 EDT 2005
Hi all.
Earlier, I queried about sql expressions in where clauses. Glynn proposed a
fix for that using additional rules to cope with operator precedence. I attach
a patch that uses the precedence directives available to bison. This allows
for eg:
select cat from blah where (col1/(col2+col3)-col4)=1
However, I'm unsure about %left and ilk directives in older yaccs; could
anybody confirm this works in non-GNU yaccs? If so, please test this patch, it
is a bugfix actually.
Daniel.
-- Daniel Calvelo Aros
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050610/434a11e7/aritwhereexp.obj
