[GRASS5] sql expression weirdnesses
Glynn Clements
glynn at gclements.plus.com
Sat Jun 11 00:15:55 EDT 2005
Daniel Calvelo Aros wrote:
> > The SQL parser doesn't implement the normal precedence rules for
> > arithmetic operators, so e.g.:
[snip]
> Thanks for looking into it. I feared it would be a parser bug. IMHO a serious
> one... Well, time to dig back into yacc. Anybody feeling like doing it in my
> not-fully-acquainted-with-dbmi place?
Try the attached patch. It compiles OK (on Linux), but I haven't
tested it.
Index: lib/db/sqlp/lex.l
RCS file: /grassrepository/grass51/lib/db/sqlp/lex.l,v
retrieving revision 1.19
diff -u -r1.19 lex.l
--- lib/db/sqlp/lex.l 9 Sep 2004 20:02:23 -0000 1.19
+++ lib/db/sqlp/lex.l 11 Jun 2005 04:13:57 -0000
@@ -82,18 +82,6 @@
- * ARITHMETICAL OPERATOR
- * Conflict of * as operator with * as all columns, what to do?
- yylval.strval = (char*)strdup(yytext);
- return ARITHMETICAL_OPERATOR;
* COMPARISON OPERATOR
Index: lib/db/sqlp/yac.y
RCS file: /grassrepository/grass51/lib/db/sqlp/yac.y,v
retrieving revision 1.20
diff -u -r1.20 yac.y
--- lib/db/sqlp/yac.y 9 Sep 2004 20:02:23 -0000 1.20
+++ lib/db/sqlp/yac.y 11 Jun 2005 04:13:57 -0000
@@ -41,13 +41,14 @@
/* operators */
%type <node> y_column
%type <node> y_value
+%type <node> y_atom
+%type <node> y_product
%type <node> y_expression
%type <node> y_comparison
%type <node> y_condition
%type <node> y_sub_condition
/* literal keyword tokens */
-%token <strval> ARITHMETICAL_OPERATOR
%token <strval> COMPARISON_OPERATOR
%token <strval> NAME
%token <strval> STRING
@@ -220,14 +221,29 @@
/* Mathematical expression */
y_expression:
- y_value { $$ = $1; }
- | y_column { $$ = $1; }
- | y_expression ARITHMETICAL_OPERATOR y_expression {
- $$ = sqpNewExpressionNode ( sqpOperatorCode($2), $1, $3 );
+ y_product { $$ = $1; }
+ | y_expression '+' y_product {
+ $$ = sqpNewExpressionNode ( sqpOperatorCode("+"), $1, $3 );
+ | y_expression '-' y_product {
+ $$ = sqpNewExpressionNode ( sqpOperatorCode("-"), $1, $3 );
- | y_expression '*' y_expression {
+y_product:
+ y_atom { $$ = $1; }
+ | y_expression '*' y_atom {
$$ = sqpNewExpressionNode ( sqpOperatorCode("*"), $1, $3 );
+ | y_expression '/' y_atom {
+ $$ = sqpNewExpressionNode ( sqpOperatorCode("/"), $1, $3 );
+y_atom:
+ y_value { $$ = $1; }
+ | y_column { $$ = $1; }
+ | '(' y_expression ')' { $$ = $2; }
/* Value used in expressions */
