[GRASS5] [bug #3346] (grass) WISH.. DXF to GRASS Vector
Request Tracker grass-bugs at intevation.de
Mon Jun 13 08:00:20 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3346
Subject: WISH.. DXF to GRASS Vector
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: GRASS6.1
Ravi Kumar, WISH
This is what we follow for
Scanned Map --> Raster -->DXF -->ARC-INFO Vector.. Wish it is possible for
Qcad dxf to GRASS vector also ..
There is a very quick method,
>> > 1. where all the digitization is done by the not so
>> > computer savvy draftsmen using Qcad.
>> > 2. Then the Geologist imports it into ARC-INFO (after the WISH to GRASS)to
>> > convert into a digital data with a vital link
>> > attribute. The attribute is an inscribed text of a link attribute in a polygon.
>> > 3. The geologist then attaches an external database
>> > table using this link attribute.
>> > If U can make such a thing possible in grass, then we
>> > can use OGLed Qcad on linux, for the draftsmen and
>> > GRASS for the Geologists.
-------------------------------------------- Managed by Request Tracker
