[GRASS5] PATCH: sql expression parser
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Jun 14 04:22:08 EDT 2005
On Tue, 14 Jun 2005, Glynn Clements wrote:
> I suspect that needs to be conditionalised, e.g.
> #ifdef YY_CURRENT_BUFFER
> 	yy_flush_buffer(YY_CURRENT_BUFFER);
> #endif
That makes it compile (obviously)---I've committed this and the
surrounding of the comments by %{ / %} to CVS and it now compiles on
Solaris. Ready to accept the patch for correct arithmetic precedence if it
is tested enough.
Paul
