[GRASS5] usability tweak on OSX
Glynn Clements
glynn at gclements.plus.com
Tue Jun 14 23:10:41 EDT 2005
Hamish wrote:
> > > - eval exec -- xterm -e $env(GISBASE)/etc/grass-run.sh $cmd $args &
> > > + eval exec -- xterm -geometry -50-40 -e $env(GISBASE)/etc/grass-run.sh $cmd $args &
> > We definitely shouldn't be hardcoding xterm placement inside d.m.
> Why not? Will it break something or is it just bad practice to do so?
Bad practice. Specifying -geometry will override most of the
mechanisms by which the user can configure the placement.
> It's just hinting that it wants to be a little towards the center
> of the screen from the bottom right corner, whatever that may be.
> My linux WM (sawfish) will ignore X -geometry if I've given explicit
> instructions for a certain window name to go somewhere.
Other WMs may be the other way around, i.e. WM-based configurations
are used as a fallback if the application doesn't explicitly specify
placement.
> > then place GRASS xterms using X resources, i.e.
> > *xterm-grass.geometry: -50-40
> No problem for me, but way too involved for avg Mac user. And avg Mac
> user is the one using d.m and spawning windows all over the place,
> not me. So why go to the trouble? Can't we just set good defaults &
> let the advanced users override with their WM if they want to?
In general, per process settings (e.g. a -geometry switch) are
supposed to override any "global" settings (e.g. WM configuration
files).
While there may be WMs which have it backwards, we shouldn't be
assuming that is the case.
