[GRASS5] [bug #3350] (grass) ps.map: vpoints draws before grid
Hamish
hamish_nospam at yahoo.com
Mon Jun 20 22:02:05 EDT 2005
I'm short on time (currently in the hardcopy output stage you see...) so
I won't address larger issues right now (e.g. ordering of layers), but:
> >> I think a big improvement would also be choosing only one method
> >> for the fontsize in all instructions, dropping "width"
> >> sub-instruction in "text" section, adding "bold" and "italics" for
> >> all instructions realated to font. Do you think these would be
> >> usefull and possible to apply?
> > I find this to be frustrating too, so both are on my TODO list.
> > re. font sizing. Yes, the text, labels, and comments instructions
> > are awkward. If you don't give "text" a fontsize it defaults to
> > 10points. Currently I edit the .ps file in a text editor to change
> > that to 8points or whatever if I need to. But I'm not going to drop
> > existing functionality just becasue I don't use it (ie ground based
> > sizing).
> > You can do bold or italics by changing the "font" subinstruction I
> > think. Watch this space. text+labels really need better fontsize
> > control.
> > e.g. bold:
> > comments comments.txt
> > where 1.0 10.8
> > font Helvetica Bold
> > fontsize 13
> > end
I have just added a "fontsize" sub-command to the "text" command and
v.labels parsing code in ps.map. enjoy.
> Can you tell what is the reason for ground based font sizing in map
> production?
No, I can't.
> > Specifically: if the "where" x,y contains a %, use percentage of map
> > window instead of inches for decorations. ie "x y" instead of "x%
> > y%" use inches. Both ways have their merits & uses.
> And both either x%,y% or x,y will be possible to use in any
> instruction which requires position? That'd be excellent.
Yes. If it sees the "%" it calculates based on position in the map box.
I had a cursory look at doing this last night for the scalebar. It
wasn't as easy as I first thought so I won't get to this in the near
future.
> Please let me bother you with some remarks on ps.map. I'd be grateful
> if you could take a look.
> 1. Problems with margins ie. the black frame extents. The bottom
> cannot be set eg. to 0. The possible minimun is always the S region
> value. Also, when using 0 for top and right the output is not like one
> would expect, and different in regard to paper size. Eg. in case of a4
> the resulting top and right borders are trunctated. In the opposite I
> recall when I used some non-standard paper size I got a one pixel
> column of map canvas standing out the frame, while the three other
> borders where ok. What could it be?
bug probably. Can you provide a ps.map command file using the spearfish
dataset which reproduces this?
"maploc" will auto-adjust itself to the default margin limits or as defined
in the "paper" command.
> 2. How to get rid of the frame for good?
command file: Don't know. (that doesn't mean it isn't possible)
in the code: find where it draws it, /* comment it out */, and recompile.
may require trial and error, but easier than you might think.
> 3. Could there be a 'presentation slide' paper size preset added (bad
> idea?)?
Yes, but what resolution? Generic .eps + 1.3333:1 aspect ratio?
Using d.* + d.out.png is better for this?
ps -> png:
pstoimg -aaliastext -flip r90 -out output.png -scale 1.3 -crop a input.ps
('pstoimg' is part of the latex2html debian package)
> 4. Regarding the manual: could the mapping instructions be grouped
> into thematic sections instead of alphabetical order? Say general
> options, rasters, vectors, decorations, externals (for eps, psfile,
> read). Much easier to learn then in my opinion.
I've added internal links to the help page in CVS:
http://grass.ibiblio.org/grass61/manuals/html61_user/ps.map.html
Hopefully it makes the HTML version of the man page easier to use.
Hamish
