[GRASS5] v.in.ascii
Helena Mitasova
hmitaso at unity.ncsu.edu
Wed Jun 22 00:03:41 EDT 2005
Hamish,
I just updated GRASS6 from cvs and for me your example runs:
(looking at your prompt GRASS:6.1-cvs and mine GRASS 6.0.cvs am I using
a different version of GRASS? - I will check with Markus tomorrow).
Can somebody else run the same thing as shown below?
Helena
GRASS 6.0.cvs (wakestate):~/lgrass > echo "1|2|3" | v.in.ascii
out=test456
Maximum input row length: 6
Maximum number of columns: 3
Minimum number of columns: 3
column: 1 type: integer
column: 2 type: integer
column: 3 type: integer
Building topology ...
1 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 1
Number of primitives: 1
Number of points : 1
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
On Jun 21, 2005, at 9:23 PM, Hamish wrote:
>> That v.in.ascii problem is a big one for me -- I suppose it's the same
>> problem I'm having trying to bring in point data. Are there any work
>> arounds in the mean time?
> Can you describe again the problem you are seeing?
> Failure to import more than 50,000 points in 6.0.0? (out of memory)
> Failure to import more than 3,000,000 points in 6.1-cvs? (out of
> memory)
> Failure to import any points in 6.1-cvs? (see below)
> Right now, I'm getting this. (fresh & latest CVS, in a new mapset)
> GRASS:6.1-cvs > echo "1|2|3" | v.in.ascii out=test654
> DBMI-DBF driver error:
> Incompatible value type.
> Error in db_execute_immediate()
> ERROR: Cannot insert values: insert into test654 values ( 1, '1', '2',
> '3')
> GRASS:6.1-cvs > db.connect -p
> driver:dbf
> database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> schema:(null)
> group:(null)
> thanks,
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
