[GRASS5] r.flow: strange compile error M_PI
Markus Neteler
neteler at itc.it
Wed Jun 22 22:25:54 EDT 2005
On Wed, Jun 22, 2005 at 07:04:55PM -0700, Brad Douglas wrote:
> On Thu, 2005-06-23 at 00:12 +0200, Markus Neteler wrote:
> > Hi,
> > after an update of the Linux OS, I am no longer able to
> > compile r.flow:
> > thuille:r.flow[281.25] make
> > gcc -I/hardmnt/thuille0/ssi/software/cvsgrass61/include -I/hardmnt/thuille0/ssi/software/cvsgrass61/dist.i686-pc-linux-gnu/include/grass -g -Wall -ansi -Wall -Wconversion -Wno-implicit-int -I/usr/local/include -DPACKAGE=\""grassmods"\" -I/hardmnt/thuille0/ssi/software/cvsgrass61/include -I/hardmnt/thuille0/ssi/software/cvsgrass61/dist.i686-pc-linux-gnu/include/grass \
> > -o OBJ.i686-pc-linux-gnu/aspect.o -c aspect.c
> > aspect.c: In function `aspect_fly':
> > aspect.c:50: error: `M_PI' undeclared (first use in this function)
> > aspect.c:50: error: (Each undeclared identifier is reported only once
> > aspect.c:50: error: for each function it appears in.)
> > make: *** [OBJ.i686-pc-linux-gnu/aspect.o] Error 1
> > thuille:r.flow[282.26] cat /etc/issue
> > Red Hat Enterprise Linux WS release 4 (Nahant Update 1)
> > Kernel \r on an \m
> > It should be in math.h, right?
> > How to debug such things?
> Yes, it should be in <math.h>, but it's not defined on all systems. I
> don't understand it being missing from your system, either.
Sorry, forgot to post that. Yes, it is defined:
grep M_PI /usr/include/math.h
# define M_PI 3.14159265358979323846 /* pi */
# define M_PI_2 1.57079632679489661923 /* pi/2 */
# define M_PI_4 0.78539816339744830962 /* pi/4 */
# define M_PIl 3.1415926535897932384626433832795029L /* pi */
# define M_PI_2l 1.5707963267948966192313216916397514L /* pi/2 */
# define M_PI_4l 0.7853981633974483096156608458198757L /* pi/4 */
> Generally, I add the following to the source that uses it:
> #ifndef M_PI
> #define M_PI 3.14...
> #endif
Could be a way out, but since it is defined... Strange.
I have
gcc version 3.4.3 20050227 (Red Hat 3.4.3-22.1)
Markus
