[GRASS5] segment lib speed patch
Markus Neteler
neteler at itc.it
Mon Jun 27 11:03:56 EDT 2005
to speed up the creation of segments in lib/segment/format.c,
a colleague from ITC-irst proposes the attached patch.
I used it locally for quite a while without having problems.
I would like to hear you opinion:
- any objections to include it (removing the old version)?
- should it be conditionalized for GNU/Linux only or
anything else (means: modifying the current condition ORIG)?
Thanks
Markus
Index: format.c
RCS file: /grassrepository/grass6/lib/segment/format.c,v
retrieving revision 2.0
diff -u -r2.0 format.c
--- format.c 9 Nov 2004 13:09:30 -0000 2.0
+++ format.c 27 Jun 2005 15:00:31 -0000
@@ -113,6 +113,7 @@
static int zero_fill(int fd, long nbytes)
+#ifdef ORIG
char buf[10240];
register char *b;
register int n;
@@ -133,4 +134,19 @@
nbytes -= n;
return 1;
+#else
+ char buf[10];
+ buf[0]=0x0;
+ G_debug(3,"Using new segmentation code...");
+ if ( lseek(fd,nbytes-1,SEEK_SET) < 0 ) {
+ G_warning("%s\n",strerror(errno));
+ return -1;
+ if(write (fd,buf, 1) != 1) {
+ return -1;
+ return 1;
+#endif
