[GRASS5] [bug #3376] (grass) r.in.gdal: UInt16 colr map goes to full 65535
Request Tracker
grass-bugs at intevation.de
Tue Jun 28 07:22:06 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3376
Subject: r.in.gdal: UInt16 colr map goes to full 65535
I just r.out.gdal'd a DEM as UInt16 which copies out the color table.
Then as a check I reimported it with r.in.gdal.
The "COPYING COLOR TABLE" took a while.
d.rast took a long while too. (killed it)
Turns out that while my file had values ~ 0-1000, the colr/ file had entries
of "0" for each int up to 65535 (as does the GeoTIFF as shown by gdalinfo*).
vi took care of that. :)
[*] Color Table (RGB with 65536 entries)
Two things would be nice:
a) r.out.gdal shouldn't export 64k color tags, only up to max
b) r.in.gdal is smart enough to add as the last colr rule max:0 65535:0 ?
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
