[GRASS5] Vector library documentation
benducke at compuserve.de benducke at compuserve.de
Thu Jun 30 13:14:09 EDT 2005
Yes, that is a very good idea. I remember getting
quite frustrated when I started GRASS 6 vector
programming, because there was so little information.
This is very unfortunate, because the new vector API
is actually quite simple and straight-forward.
I remember that I did try to make some notes back then,
maybe I can find them and add them to the docs.
I am still confused about one thing:
The GRASS 6 homepage says that 3D topology is supported.
In the source files themselves, however, there is a
comment somewhere that says this is not true. So:
Are operations like "point in sphere" possible with
the current vector API or not?
Best
Benjamin
----- Originalnachricht -----
Von: Markus Neteler <neteler at itc.it>
Datum: Donnerstag, 30. Juni 2005 4:52 pm
Betreff: [GRASS5] Vector library documentation
> Hi,
> as we know there is some confusion/lack of knowledge about
> the GRASS 6 Vector library.
> I suggest to *document* our knowledge, and to do so in the
> Programmer's manual which is integrated into the source
> code base on doxygen.
> A) To generate the vector part of the current Programmer's manual,
> simply do:
> cd lib/vector
> make htmldocs
> #or:
> make pdfdocs
> This extracts all Vect_*() functions from the C code and
> auto-generates doxygen files. These are reachable through
> lib/vector/vector_arch.dox
> which provides a draft (!) overview. Please extend also
> this file.
> To look at the HTML version (similar for PDF):
> konqueror html/index.html
> To cleanup, simply run
> make cleandocs
> B) To insert missing documentation:
> - each C file in the library should come with a comment
>   in doxygen style.
> - have a look at existing code how to do that. Note that
>   a fraction of the functions is not yet documented in an
>   optimal way
> - if a function doesn't appear in the programmer's manual,
>   this indicates that the doxygen-style documentation isn't
>   complete
> The full documentation is also posted every Saturday morning
> automatically on the GRASS web server/Development section.
> C) TODO
> Please transfer your knowledge into the code documentation
> to enable more people to do GRASS programming. This applies to all
> code sections. The related DBMI library is basically undocumented.
> Whenever you know a bit more than explained in the source code,
> add that piece to CVS.
> Markus
> PS: I have updated a couple of missing function docs today in Vlib,
>    please update from 6.1-CVS first.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
