[GRASS5] Re: [bug #3023] (grass) r.fillnulls doesn't work
Maciek Sieczka
werchowyna at pf.pl
Tue Mar 1 10:57:10 EST 2005
From: "Hamish via RT" <grass-bugs at intevation.de>
>> r.fillnulls fails in such a way:
>> GRASS 6.0.cvs:~ > r.fillnulls input=N51E016_nowy
>> output=N51E016_nowy.fld Using tmp file r_fillnulls_4707
>> Locating and isolating NULL areas...
>> 100%
>> r.buffer: 00000000 - illegal distance specification
>> ERROR detected: /usr/local/grass-6.0.cvs/scripts/r.fillnulls
>> abandoned. Removing temporary map:
>> > .. pretty much everything will be broken after the r.buffer step
>> > fails. Please try again with the two updated scripts.
>> As you said...
> well at least it fails gracefully now.
> hmmm. I've just downloaded the N51E016 SRTM data and r.fillnulls
> works fine for me.
> Lat/lon location, right?
> GRASS> g.proj -p
yes:
GRASS 6.0.cvs:~ > g.region -p
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 52:00:01.5N
south: 50:59:58.5N
west: 15:59:58.5E
east: 17:00:01.5E
nsres: 0:00:03
ewres: 0:00:03
rows: 1201
cols: 1201
> what do you get if you type this at a command prompt:
> echo "0.3 0.3" | awk '{printf "%.8f\n", ($1 + $2)}'
> 00000000 or 0.60000000 ?
Neither:
GRASS 6.0.cvs:~ > echo "0.3 0.3" | awk '{printf "%.8f\n", ($1 + $2)}'
0,00000000
"," instead of "." - would that be the issue? I Poland, in opposite to the
normal world, we use the coma as the decimal point deliminator. Does
r.fillnulls rely on local system settings?
Maciek
