[GRASS5] [bug #3049] (grass) ps.map
Hamish
hamish_nospam at yahoo.com
Tue Mar 1 17:49:00 EST 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3049
> GRASS Version: grass-6.0.cvs_src_snapshot_2005_02_12
> ps.map input=ps2.txt output=map1.ps
> ERROR: color purple : illegal color request
> although ps.map.html says it is supported:
> NAMED COLORS
> The following are the colors that are accepted by ps.map:
> <snip>
> purple
> red
> violet
> white
> yellow
purple is not a standard GRASS color given by D_color_list(), but is
defined in ps/ps.map/ps_colors.c:
static struct {
char *name;
float r, g, b;
} colors[NUM_COLORS] =
{"white", 1.00, 1.00, 1.00},
{"black", 0.00, 0.00, 0.00},
{"red", 1.00, 0.00, 0.00},
{"green", 0.00, 1.00, 0.00},
{"blue", 0.00, 0.00, 1.00},
{"yellow", 1.00, 1.00, 0.00},
{"magenta", 1.00, 0.00, 1.00},
{"cyan", 0.00, 1.00, 1.00},
{"aqua", 0.00, 0.75, 0.75},
{"grey", 0.75, 0.75, 0.75},
{"gray", 0.75, 0.75, 0.75},
{"orange", 1.00, 0.50, 0.00},
{"brown", 0.75, 0.50, 0.25},
{"purple", 0.50, 0.00, 1.00},
{"violet", 0.50, 0.00, 1.00},
{"indigo", 0.00, 0.50, 1.00}
my guess is that for some ps.map functions "purple" works, for others it
doesn't.
For consistency & simplicity, we should probably just use standard grass
colors here? Better yet use grass lib functions for colors.
PostScript needs R:G:B as 0.0-1.0 not 0-255, so some scaling is needed.
Hamish
