[GRASS5] AW: [winGRASS] Updated CygwinGRASS-0.2.1
    Marco Lechner
    marco.lechner at geographie.uni-freiburg.de
    Wed Mar  2 04:53:47 EST 2005
How to create a CygwinGRASS-CD!!
I just took a clean M$ Windows Computer startet the X-Cygwin Installation
(incl. your GRASS repository) and choosed "download only" to produce a local
package repository. Afterwards I renamed the mirror-folders in the
repository-folder to "release". I created a folder grass60 in the release
folder and copied your grass packages into it). At last I modified the
setup.ini in the repositoryfolder (added the packages from your setup.ini
and modified the path - at last told the package "@ base-files" that it
requires "grass" to make sure grass is installed by default) - created a
CD-Image ready.
In short terms: the Default Installation includes all the Cygwin-Stuff that
is installed with a normal X-Cygwin installation and your packages (and all
the packages that are required by your packages). On the CD there are a lot
of more packages available (i.e. apache, gcc, openldap, tetex, ...) wich can
be added as usual.
Marco
P.S. if a single package is updated you only have to put the new version in
the releasefolder and change the md5sum in the setup.ini - its easier than
creating the whole local package repository again.
-----Ursprüngliche Nachricht-----
Von: Huidae Cho [mailto:grass4u at gmail.com]
Gesendet: Dienstag, 1. März 2005 18:19
An: Marco Lechner
Cc: Grass Maillist Verein; GRASS Internat; wingrass at grass.itc.it
Betreff: Re: [winGRASS] Updated CygwinGRASS-0.2.1
Thank you for your installation CD. Does this include all cygwin stuff
to install grass and how does it work? setup.exe with local directory
or customized setup.exe? Just curious. :-)
Huidae Cho
On Tue, Mar 01, 2005 at 05:25:05PM +0100, Marco Lechner wrote:
> The CygwinGRASS InstallationCD is updated with the newest cygtiff-5.dll
and
> the "easystart" GRASS.bat from Huidae Cho. By the way thanks for all the
> work at this point.
> https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS/
> Marco
> P.S. Installing GRASS with Cygwin on Windows was never this easy!
> Marco Lechner
> dienstlich:
> Institut für Physische Geographie
> Uni Freiburg
> Werderring 4
> 79085 Freiburg
> Fon 0761 / 203-3548
> Mail marco.lechner at geographie.uni-freiburg.de
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
