[GRASS5] Re: [GRASSLIST:5971] r.area ?
Jachym Cepicky
jachym.cepicky at centrum.cz
Thu Mar 3 02:03:41 EST 2005
what about this (attachement)
Jáchym
On Thu, Mar 03, 2005 at 02:39:05PM +1300, Hamish wrote:
> > is there some raster module, which would assign new values to raster,
> > based on area size of grouped cells? Something like the Area module in
> > Idrisi Kilimanjaro...
> maybe with the r.to.vect module then vector command magic? (starting
> with d.what.vect)
> or use r.mapcalc if(value < this && value > that,1,0)
> then 'r.stats -a' to get an area total.
> maybe r.reclass + 'r.stats -a'?
> Hamish
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
#!/usr/bin/perl -w
use strict;
# # LICENCE
# # This script creates new map, which category values will represent
# # area of grouped cells
# # Copyright (C) 2005 Jachym Cepicky
# # This program is free software; you can redistribute it and/or modify
# # it under the terms of the GNU General Public License as published by
# # the Free Software Foundation; either version 2 of the License, or
# # (at your option) any later version.
# # This program is distributed in the hope that it will be useful,
# # but WITHOUT ANY WARRANTY; without even the implied warranty of
# # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# # GNU General Public License for more details.
# # You should have received a copy of the GNU General Public License
# # along with this program; if not, write to the Free Software
# # Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
# autor Jachym Cepicky jachym.cepicky [at] centrum [dot] cz
# URL: http://les-ejk.cz
unless($ENV{GISBASE}){
print STDERR "\n\nYou have to run GRASS first!\n\n";
exit;
my @arg = &load_arguments();
if ($arg[0] eq '0') {
&print_help();
my @mapcalc_str = &reclass();
#print $mapcalc_str;
open (TMP,">/tmp/grass.r.area.txt") or die "Could not open file /tmp/grass.r.area.txt: $!\n";
print TMP @mapcalc_str;
close TMP;
system("cat /tmp/grass.r.area.txt|r.reclass in=$arg[0] out=$arg[1]; rm /tmp/grass.r.area.txt");
sub reclass
my $line = ""; # line with category from r.report
my $cat = 0; # category number
my $area = 0; # category area
my @mapcalc_str = ();
foreach $line (`r.report -heqnN map=$arg[0] units=$arg[2]`) {
next unless ($line =~ m/(\. )+/);
#| 13| . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .| 1.00|
# searching for category
$cat = $line;
$cat =~ s/^\|\s*([0-9]+)\|.*$/$1/;
chomp $cat;
# searching for area
$line =~ m/\. ?\|\s*(([0-9]+,)?[0-9]+(\.[0-9]+))\|$/;
$area = $1;
$area =~ s/,//g;
#print "$area\n";
push @mapcalc_str, "$cat = $area\n";
push @mapcalc_str, "end\n";
return @mapcalc_str;
sub load_arguments{
my $in="";
my $out="";
my $units="";
# arguments of command line
foreach(@ARGV){
if(m/help/i){
return 0;
} elsif(m/in/i){ s/^.*=//;$in = $_;
} elsif(m/out/i){ s/^.*=//;$out = $_;
} elsif(m/un/i){ s/^.*=//;$units = $_;
# testing of parameters
if ($in eq ""){
print STDERR "\nERROR: Parameter input not defined\n\n";
return 0;
if ($out eq ""){
print STDERR "\nERROR: Parameter output not defined\n\n";
return 0;
if ($units eq ""){
print STDERR "\nERROR: Parameter units not defined\n\n";
return 0;
# all arguments back
return ($in, $out, $units);
sub print_help
print qq(
\nDescription:\n
This skript creates new map, in which groups will have area size as cat. label
Usage:
r.area in=name out=name units=name
Parameters:
in Name of input vectorfile, containing points
output Name of resulting vector file
units mi(les),me(ters),k(ilometers),a(cres),h(ectares),c(ell_counts),p(ercent_cover)
exit;
