[GRASS5] Angle of incidence in viewshed/line of sight
Benjamin Ducke benducke at compuserve.de
Thu Mar 3 15:33:12 EST 2005
On Wed, 2 Mar 2005 13:28:14 +1300
Hamish <hamish_nospam at yahoo.com> wrote:
> > Just so we don't re-invent the wheel, has anyone developed the code
> > for evaluating the angle of incidence from a single point in the
> > landscape (i.e. the point used for r.los) to cells within the
> > viewshed? I am analyzing repeated historical topographic survey
> > photographs (more on this later) and want to account for components of
> > registration and classification error due to terrain (angle of
> > incidence). I have looked at the code for r.los and r.sun and will be
> > seeking help from some students in our new computer science/geomatics
> > programme as I am not (yet) a programmer. Look forward to any
> > suggestions...
> Yes, I have done this some time ago.
> I modified r.los to return horizontal angle to target instead of
> vertical angle to target for the values in the resultant raster map. This
> was for GRASS 5.0, but it should work for 6.0 just as well I think. If
> you want I can supply the code.
> r.los is a real mess and doesn't scale well to larger grid sizes.
> Be sure to check out r.cva as well:
>   http://www.ucl.ac.uk/~tcrnmar/GIS/r.cva.html
The GRASS 5 version of r.cva is currently broken due to a bug
in the floating point raster code I introduced myself (ahem).
I will have finished an updated version for GRASS 6 next week
that fixes the bug, handles vector points for observer positions
and introduces attributes for observer positions just
like Argh!nfo's Spatial Analyst uses.
I'll ask Mark Lake to update the file on his webpage then.
Regards,
Benjamin.
> r.sunmask with altitude and azimuth options might be another way.
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
