[GRASS5] v.in.ascii import failure
Otto Dassau otto.dassau at gmx.de
Fri Mar 4 13:17:36 EST 2005
in GRASS 6.0 cvs, there is a problem importing ascii coordinate pairs with v.in.ascii. Using cat test.txt | v.in.ascii fs='|' out=mymap doesn't work:
599251|4927066
599090|4926953
599097|4926472
599280|4925969
599863|4926391
599849|4926841
Error:
Maximum input row length: 16
Maximum number of columns: 2
Minimum number of columns: 2
ERROR: y column is not of number type
simply adding an ID (or another 3rd column) works:
1|599251|4927066
2|599090|4926953
3|599097|4926472
4|599280|4925969
5|599863|4926391
6|599849|4926841
Maximum input row length: 18
Maximum number of columns: 3
Minimum number of columns: 3
column: 1  type: integer
column: 2  type: integer
column: 3  type: string  length: 8
Building topology ...
6 primitives registered
Building areas:  100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:  100%
Topology was built.
Number of nodes     :   6
Number of primitives:   6
Number of points    :   6
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
Why is this? Do I always need 3 columns?
ciao
 Otto
