[GRASS5] Re: options order in GUI
Michael Barton
michael.barton at asu.edu
Tue Mar 8 11:38:09 EST 2005
This is not something I can fix. It is built into the v.clean module.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at pf.pl>
> Date: Tue, 08 Mar 2005 12:21:43 +0100
> To: Radim Blazek <blazek at itc.it>, <michael.barton at asu.edu>
> Cc: grass devel <grass5 at grass.itc.it>
> Subject: options order in GUI
> regarding bug http://intevation.de/rt/webrt?serial_num=3017
> Maciek Sieczka wrote:
>> I encounter a segfault with one particular dataset with the following
>> options:
>> GRASS 6.0.cvs:~ > v.clean input=i output=j type=area err=j_err
>> tool=break,rmdupl,rmdac,bpol,rmarea
> Radim Blazek wrote:
>>> I fixed that, however:
>>> 1) bpol should be used as first cleaning tool, it does the same as
>>> break, but it is faster on clean (identical boundaries) polygons
> I can't change the order of cleaning tools using v.clean in GUI. The order
> is hardcoded. Could that be fixed Michael? Options order issue also refers
> to v.type in GUI http://intevation.de/rt/webrt?serial_num=2969.
>>> 2) bpol works only with type=boundary, the same break,rmdupl etc.
> Radim, do you mean that "rmdupl" and "break" should not be used with
> type=line?
> Maciek
