[GRASS5] [bug #3081] (grass) Raster with 256 levels per color fails to show
Glynn Clements
glynn at gclements.plus.com
Sun Mar 13 18:59:17 EST 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3081
> Subject: Raster with 256 levels per color fails to show
> GRASS Version: 6.0.cvs 20050212
> Rasters created with r.composite and 256 levels systematically fails
> to show. It works with 32 levels.
Using "r.composite ... levels=256" will result in rasters with huge
colour tables (65536 rules). Operations which use the colour table
(e.g. d.rast) may be slow and/or consume large amounts of memory
(possibly more memory than is available, resulting in the program
terminating abnormally).
