[GRASS5] dbmi Protocol Error with v.db.connect
Radim Blazek
blazek at itc.it
Mon Mar 14 03:06:41 EST 2005
Allan Metts wrote:
> Hi everyone,
> This is my first attempt to access the attributes of a shape file, with the shape file existing elsewhere -- and linked using v.external. Obviously I'm doing something wrong here -- can someone set me straight?
> Thanks in advance!
> Allan Metts
> GRASS 6.0.cvs (gdt_streets):~ > v.external dsn=/airsage/spatial_data/gdt/streets/ layer=moxxxxst output=moxxxxst
> Building topology ...
> Feature: 1150266
> Topology was built.
> Number of nodes : 769628
> Number of primitives: 1150266
> Number of points : 0
> Number of lines : 1150266
> Number of boundaries: 0
> Number of centroids : 0
> Number of areas : 0
> Number of isles : 0
> GRASS 6.0.cvs (gdt_streets):~ > v.db.connect -p moxxxxst
> Vector map <moxxxxst> is connected by:
> layer <1> table <moxxxxst> in database </airsage/spatial_data/gdt/streets/> through driver <ogr> with key <FID>
> GRASS 6.0.cvs (gdt_streets):~ > v.db.connect -c moxxxxst
> dbmi: Protocol error (invalid table/column name or unsupported column type)
> ERROR: Cannot open table <moxxxxst>
There was a bug in ogr driver. v.db.connect -c was also buggy. Both fixed.
Radim
