[GRASS5] v.category - adding table name
Radim Blazek
blazek at itc.it
Tue Mar 15 04:55:44 EST 2005
> + Fi = Vect_get_field (&In, field);
> + freps[fld]->table = G_store (Fi->table);
You must check if the connection exists, Vect_get_field can return NULL
if the connection to database was not defined, then G_store (Fi->table)
will crash.
Radim
Martin Landa wrote:
> Hi,
> I have written a simple patch for v.category. I hope it would
> be useful for many GRASS users (?).
> Original report:
> LAYER 1:
> type count min max
> LAYER 2:
> type count min max
> Adding _table_name_:
> LAYER/TABLE 1/test_obrazy_parcel:
> type count min max
> LAYER/TABLE 2/test_parcely:
> type count min max
> Martin
> Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
> CTU Prague, Faculty of Civil Engineering, Czech Republic
> *** main.c.old 2005-03-13 13:47:05.000000000 +0100
> --- main.c 2005-03-13 13:56:29.000000000 +0100
> *** 39,44 ****
> --- 39,45 ----
> typedef struct {
> int field;
> + char *table;
> int count[FRTYPES];
> int min[FRTYPES], max[FRTYPES];
> } FREPORT;
> *** 49,54 ****
> --- 50,56 ----
> struct Map_info In, Out;
> static struct line_pnts *Points;
> struct line_cats *Cats;
> + struct field_info *Fi;
> int i, j, ret, option, otype, type, with_z, step;
> int n_areas, centr, new_centr;
> double x, y;
> *** 326,331 ****
> --- 328,335 ----
> fld = nfreps - 1;
> freps[fld] = (FREPORT *) calloc ( 1, sizeof (FREPORT));
> freps[fld]->field = field;
> freps[fld]->count[rtype]++;
> *** 370,376 ****
> freps[i]->count[FR_AREA], freps[i]->min[FR_AREA],
> freps[i]->max[FR_AREA]);
> } else {
> ! fprintf (stdout, "LAYER %d:\n", freps[i]->field);
> fprintf (stdout, "type count min max\n");
> fprintf (stdout, "point %7d %10d %10d\n",
> freps[i]->count[FR_POINT],
> --- 374,380 ----
> } else {
> ! fprintf (stdout, "LAYER/TABLE %d/%s:\n", freps[i]->field, freps[i]->table);
