[GRASS5] New NVIZ fly navigation
Helena hmitaso at unity.ncsu.edu
Tue Mar 15 22:38:59 EST 2005
It works fine, I got an error message on my home machine too, but it showed up
only the first time I loaded g3d file and never again, so I assume it was my local
problem.
thank you once more,
Helena
> Thank you.
>> I had only one problem - when I tried to read g3d file to see whether it
>> will work with the volume data I got an error message
>> id in get_drawmode is invalid.
>> I will try at home on a different machine, but maybe be somebody who
>> has the slovakia3d data set installed could test it for volume data too.
>> Helena
> I didn't have the chance to try it with volume data. As I changed
> something to the command Ndraw_all I can expect some problem, but I used
> the same functions as in draw.c eliminating only the swap buffer
> functions between the drawing of surf, vect, sites and volumes to avoid
> the flickering. Check the differences between Ndraw_all_cmd (draw.c) and
> Ndraw_all_together_cmd (togl_flythrough.c) if you want to see what has
> changed.
> Please, let me know what happens with the further tests.
> Massimo
