[GRASS5] v.in.ascii updates
Daniel Calvelo Aros
dcalvelo at minag.gob.pe
Sun Mar 20 14:05:26 EST 2005
Sent: Sun, 20 Mar 2005 22:30:46 +1200
> > > ? skip blank lines in input file.
> > > (currently extra newlines at EOF break import of points)
> > User must be warn if there are errors in the file, empty line may be
> > error in input. There should be probably a flag for shuch skipping.
> not done. I'd like to ignore blank lines if they happen at end of
> file, but don't see an easy way of doing that. I agree that blank
> lines mid- file is an error.
In points.c, points_to_bin function, I guess.
If we are setting on:
a) blank line(s) followed by eof -> ok and
b) blank line(s) followed by non-eof -> error,
you might catch the first blank line then consume ascii_in until not blank or
eof; then the previous rule applies.
Just an idea...
Daniel.
