[GRASS5] Module memory management - G_set_error_routine()
Mon Mar 21 18:08:01 EST 2005
Brad Douglas wrote:
> Would it be acceptable practice to use the following function to free
> memory resources before exit (for fatal errors)?
The OS automatically recovers the process' memory when the process
terminates.
If you want to perform specific tasks (e.g. deleting temporary files)
upon termination, use atexit().
