[GRASS5] Re: [bug #3100] (grass) r.proj is making the asymmetric integer truncation error
Markus Neteler neteler at itc.it
Wed Mar 30 03:14:21 EST 2005
Hi Morten,
On Mon, Mar 28, 2005 at 05:21:31PM +0200, Morten Hulden wrote:
> Hi Markus,
> as I could not get write access to the cvs (public key failed) I submit
@ Bernhard: could you fix that for Morten?
> this patch to you directly as a diff file. To apply the patch you should
> go into the directory where your grass6 sources are stored
> (/usr/local/src/grass/grass6 in my case) and issue
> patch -p1 < /path/to/r.proj-20050328mhu.patch
> This patch fixes two things:
> -assymetric integer truncation error [bug #3100]
> -adds a missing offset to the initial x-coodinate for each row in the
> main projection loop. this offset causes the projection of the _center_
> of the cell instead of the border. this was always the intention but
> earlier it was only made correctly for the first row of the location.
> A set of test maps provided by Maciek Sieczka helped to spot the bugs.
I have applied the bug fixes to
- CVS 6.1
- 6.0 release branch
Thanks for fixing it,
 Markus
