[GRASS5] v.in.garmin
Hamish
hamish_nospam at yahoo.com
Wed Mar 30 19:55:40 EST 2005
> I tried the same command sequence you suggested (on a UTM zone 32
> location, import of GPS_points (track|route|waypoint) works
> fine), this is an excerpt of the error printout:
> DBMI-DBF driver error:
> Incompatible value type.
> Error in db_execute_immediate()
> ERROR: Error while executing: "INSERT INTO t1_trk VALUES (135,
> '03/27/2005
> 11:31:52', 49,0000000, 9,0000000, '03/27/2005 11:33:00',
> 49,0000000,
> 9,0000000)
ahh ok, I see the problem.
49,0000000
Awk is using the comma as a decimal place instead of a period, and so
the third column is read as 000000 not 9.0000.
see these threads, same problem but with r.fillnulls.
http://thread.gmane.org/gmane.comp.gis.grass.devel/6864
http://thread.gmane.org/gmane.comp.gis.grass.devel/6966
In r.fillnulls we could get away with replacing awk, in v.in.garmin we
really need it.
try adding
LC_ALL=C
to the start of the script or just in front of each awk command.
Hamish
