[GRASS5] more cats in one layer and where condition
Martin Landa
landa at gama.fsv.cvut.cz
Wed May 4 14:54:19 EDT 2005
Hi all,
the problem which I described in last e-mail (d.vect disp=cat|attr where=)
is more complex (as I have found out using ps.map)...
The patch for d.vect, attached to the last e-mail, is faulty. It works only
if 'where' condition or category value is set. I forgot to check 'chcat' variable.
So there is modified patch for d.vect (d.vect-patch1.tar.gz),
I hope better than the last one...
I have similar problem with ps.map. I have tried to display centroids using where
condition. No points were displayed... For example:
one centroid/point
layer/cat
50/1
50/2
attribute table:
cat | kod
1 | 18
2 | 304
input for ps.map:
vpoints bylany_hp
type centroid
layer 50
where kod=304
symbol dkm/zahrada
color black
size 7
lpos 0
label
end
--> no points found ...
In function Vect_set_varray_from_db () is used Vect_cat_get () which
finds _first_ category of given field. So in this case category '1'!
For my purpose (I am trying to develop GRASS module for importing data in Czech
cadastre exchange data format -- my diploma thesis) I have modified this function
(see array.c.patch). But I am not sure if this solution is good...
Best regards,
Martin
Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
*** array.c.old 2005-05-04 19:43:26.000000000 +0200
--- array.c 2005-05-04 19:43:58.000000000 +0200
*** 196,202 ****
Vect_set_varray_from_db ( struct Map_info *Map, int field, char *where,
int type, int value, VARRAY *varray )
! int i, n, centr, cat, *cats, ncats;
int ni = 0; /* number of items set */
int ltype; /* line type */
struct line_cats *Cats;
--- 196,202 ----
! int i, n, c, centr, cat, *cats, ncats;
*** 245,256 ****
if ( centr <= 0 ) continue; /* No centroid */
Vect_read_line (Map, NULL, Cats, centr);
! if ( !Vect_cat_get(Cats, field, &cat) ) continue; /* No such field */
if ( in_array ( cats, ncats, cat ) ) {
varray->c[i] = value;
ni++;
} else { /* Lines */
n = Vect_get_num_lines (Map);
--- 245,266 ----
! /*if ( !Vect_cat_get(Cats, field, &cat) ) continue; No such field */
! for (c = 0; c < Cats->n_cats; c++) {
! if (Cats->field[c] == field && in_array ( cats, ncats, Cats->cat[c] )) {
! cat = Cats->cat[c];
! varray->c[i] = value;
! ni++;
! break;
ni++;
*** 265,276 ****
if ( !(ltype & type) ) continue; /* is not specified type */
ni++;
--- 275,295 ----
! /* if ( !Vect_cat_get(Cats, field, &cat) ) continue; No such field */
! ni++;
! break;
ni++;
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050504/9de48c80/d.vect-patch1.tar.obj
