[GRASS5] r.out.gdal not working in CVS HEAD
John Gillette JGillette at rfmd.com
Mon May 9 12:30:36 EDT 2005
I suggest try changing from:
WKT=`g.proj -wf`
if [ -n $WKT ] ; then
  PROJECTION="-a_srs '${WKT}'"
fi
to:
WKT=`g.proj -wf`
if [ -n "$WKT" ] ; then
  PROJECTION="-a_srs ${WKT}"
fi
If that doesn't work, try this:
WKT=`g.proj -wf`
  PROJECTION="-a_srs \"${WKT}\""
fi
(untested)
REF: tldp.org "Advanced Bash-Scripting Guide", section 4.1, 7.3
John
> Dear developers,
> Last changes between 1.14 and 1.15 in CVS HEAD prevent r.out.gdal from
> working (with my maschine).
> When I revert the changes everything works well. The quoting seems to
> be messed up a bit.
> Cheers
> 	Stephan
