[GRASS5] r.out.gdal not working in CVS HEAD
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue May 10 04:15:38 EDT 2005
On Tue, 10 May 2005, Hamish wrote:
>>> Dear developers,
>>> Last changes between 1.14 and 1.15 in CVS HEAD prevent r.out.gdal
>>> from working (with my maschine).
>>> When I revert the changes everything works well. The quoting seems
>>> to be messed up a bit.
>>> Cheers
>>> Stephan
> On Mon, 9 May 2005 12:30:36 -0400
> "John Gillette" <JGillette at rfmd.com> wrote:
>> I suggest try changing from:
>> WKT=`g.proj -wf`
>> if [ -n $WKT ] ; then
>> PROJECTION="-a_srs '${WKT}'"
>> fi
>> to:
>> WKT=`g.proj -wf`
>> if [ -n "$WKT" ] ; then
>> PROJECTION="-a_srs ${WKT}"
>> fi
>> If that doesn't work, try this:
>> WKT=`g.proj -wf`
>> PROJECTION="-a_srs \"${WKT}\""
>> fi
> I commited the quoting fix on the -n line to CVS, but not the one on the
> PROJECTION line. I think "-a_srs '${WKT}'" should infact expand $WKT;
> while '-a_srs "${WKT}"' would not. Could you test?
For the record I agree with all that (I think it was my fix that broke
it), and the escaped double quotes was what I was going to change it to
too last night before I got called away to something else.
Paul
