[GRASS5] Error with langinfo.h in Mac OS X 10.2.x
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Tue May 10 10:55:28 EDT 2005
Hi Radim
>Lorenzo Moretti wrote:
>>Hi all
>>Last cvs includes in lib/gis/parser.c a link to:
>>langinfo.h
>>This file is only included in Darwin kernel from Mac OS X 10.3.x or later.
>>This is the true first incompatibility for Mac OS X 10.2.x with Grass.
>>I've compiled last cvs with old parser.c and it works.
>>I ask:
>>Is it much important this file or is it possible to work around?
>>What I lost?
>>Bye
>The langinfo.h is necessary for nl_langinfo(CODESET). We need to get
>somehow encoding of the gettext output.
>gettext is using nl_langinfo(CODESET) so I thought that if gettext
>is available and used (#if defined(HAVE_LIBINTL_H) &&
>defined(USE_NLS))
>the header file langinfo.h should be also available.
>Radim
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
I use gettext (GNU gettext) 0.10.40 for compatibility with all OS X
version (10.2 or higher). Until now it worked in all Mac OS X (10.2,
.3 and .4)
Last gettext use new libraries and new header like langinfo.h (10.3 or higher).
The problem is this one I think.
Is it possible to make a workaround ?
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
