[GRASS5] Error with langinfo.h in Mac OS X 10.2.x
Radim Blazek blazek at itc.it
Wed May 11 05:14:56 EDT 2005
Glynn Clements wrote:
> Radim Blazek wrote:
>>>Last cvs includes in lib/gis/parser.c a link to:
>>>langinfo.h
>>>This file is only included in Darwin kernel from Mac OS X 10.3.x or later.
>>>This is the true first incompatibility for Mac OS X 10.2.x with Grass.
>>>I've compiled last cvs with old parser.c and it works.
>>>I ask:
>>>Is it much important this file or is it possible to work around?
>>>What I lost?
>>>Bye
>>The langinfo.h is necessary for nl_langinfo(CODESET). We need to get
>>somehow encoding of the gettext output.
>>gettext is using nl_langinfo(CODESET) so I thought that if gettext is
>>available and used (#if defined(HAVE_LIBINTL_H) && defined(USE_NLS))
>>the header file langinfo.h should be also available.
> langinfo.h needs its own configure check.
Fixed.
Radim
